Hifiman Hm601 Slim |
19.1.2012, 13:42
Вот узнал некоторое время назад о выходе 601 в более тонком (почти на терть) корпусе. И все бы ничего, но вот спасибо ребятам из плеера дали ссылочку:
Вот из нее текст и пара фотграфий. John Sciacca on HiFiMAN 2012-1-11 12:01:21 ��My second day (third if you count media day) at International CES 2012 started with a breakfast meeting with a company that was new to me, HiFiMan. Founded by Dr. Fang Bian, this company’s goal seems to be all about bringing high-resolution audio listening to the portable world. And for people for whom “MP3” is a four-letter word, the new HM-601 Slim player will be a breath of fresh and open, high-resolution air. The player uses a Burr Brown PCM1704u decoding chip that allows it to handle decoding high-res FLAC files (at least up to 96/24), as well as Ogg, WAV, AAC, WMV, and MP3. This player allows audiophiles to enjoy their high-res music in the highest quality while still being on the go. On top of the Slim’s superb DAC, it also features an improved headphone amp section. It will be available in 4 GB ($199) and 8 GB ($249) models and can be expanded up to 32 GB by using an SD card. It also has an adjustable gain output for use with in-ear headphones and a separate high-gain output for full-sized headphones. Sticking with the theme of no-compromise mobile listening, HiFiMan also debuted its HE-400 planar magnetic design over-ear phones. These feature 92.5 dB of sensitivity, meaning they can be driven by typical iPod/Phone devices. The phones had the wonderful, open, airy mid-range sound characteristic of planar drivers as well as deep bass extension. ![]() И если честно, я немного в шоке. Или чудо, или новые технологии или работать он будет минут 20 максимум (как по питанию так и по надежности) или писатель идиот. Даже не знаю что думать! Как так. 601 сам по себе уже мелкий. Мельце него по объемуплееров которые хоть как-то претендуют на нормальный звук уже нет. Литл Доты, Колоры, Даже младшие версии типа Текласта или младшего колора - они если и тоньше то шире. Тоесть есть какой-то предел по объему в который можно впихнуть нормлаьное железо. А тут получается вынули один стереоадак (1543) и засунули ДВА более совершенных требующих большего количества деталюшек и их лучшего качества и при этом срезали корпус.... И это при том, что надо и питание сделать получается мощнее и больше. И при этом ценник остался тот же??? Мы тут как-то разбирали (ребята на производстве конечно, а не я лично) HM601 и в общем? конечно? вердикт не восторженный. За эти деньги, в таком габарите при использовании все-таки не какого-то кодека как в типовых плеерах да и с более мощным усилителем и все такое... Ясно дело - куча вещей на чем сэкономили. Например на защите от пробоя при подключении по УСБ (это, кстати основаня причина их помирания, причем такая которую не починить домашними методами). Но это... Интересно - или серкретные разрработки (батареи на фулеренах, или топливные элементы на водороде???) или просто уже сэкономили вообще на всем или писатель просто ступил, или работать он будет всего минут 20 (как по причине питания так и по причине надежности)? Или это те самые 1704 которые делают сами китайцы впихивая дешевую дельту в корпус выглядящий как именитые цапы? где-то я про такое слышал. общем боюсь как бы не получился еще один Ck4 - по описанию блеск, а по реальному положению - с легкостью заменится ковоном. Я в мелком шоке... жду аппарат. Надо посмотреть на это чудо. -------------------- |
3.2.2012, 13:37
Как оказалось - нам не показалось что в новости было "что-то не так".
Все-таки 601 Slim как был так и остался на 1543. Пока что... наверное... И если честно.. НУ да - он тоньше. 21-22 вместо 25 Звук вроде такой же. Но может чуть мягче чем на моем рокбоксеном аппарате. И вроде как ни странно - сибилянтов поменьше. Правда я еще плотно не тестил и отличия отлавливаю по памяти. Утром ехал с моим рокбоксовым, вечером - со слимовым. Может тут обед больше на звук повлиял чем что-то еще. Правда мой аппарат срокбоксом который еще и моденный. Но в целом отличия минимальны. Так что если честно обозревать там нечего. -------------------- |
28.12.2017, 20:06
Новичок ![]() Группа: Пользователи Сообщений: 5 Регистрация: 28.12.2017 Пользователь №: 111747 |
Плеер безусловно легендарный, я бы даже сказал культовый, но глядя на результаты ваших замеров, возникает резонный вопрос - неужели только из-за мультибитности? У того же hidizs 100 ттх куда лучше и они как-то больше вяжутся с отзывами
| Текстовая версия | Сейчас: 9.11.2025, 4:48 |
