Schiit Bifrost + Asgard
сообщение 8.5.2013, 18:03
Specifications*
Inputs: Coaxial SPDIF, Optical SPDIF, USB (optional)
Input Capability: up to 24/192 for all inputs
Input Receiver, SPDIF: Crystal Semiconductor CS8416
Input Receiver, USB: C-Media CM6631A
D/A Conversion IC: AKM4399
Analog Summing, Filtering: Fully Discrete, JFET differential topology
Output: RCA (single-ended)
Output Impedance: 75 ohms
Bifrost:
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2Hz-100KHz, -1dB
Maximum Output: 2.0V RMS
THD: <0.005%, 20Hz-20KHz, at max output
IMD: <0.007%, CCIR
S/N: >106dB, referenced to 2V RMS
Bifrost Uber:
THD: <0.002%, 20Hz-20KHz, at max output
IMD: <0.002%, CCIR
S/N: >110dB, referenced to 2V RMS
Power supply: 5 stages of regulation, including separate supplies for critical digital and analog sections.
Upgradability: Separate, modular USB Input Card and DAC/Analog Card are snap-in replaceable.
Power Consumption: 12W
Size: 9 x 6.75 x 2.25”
Weight: 5 lbs
*All measurements made on a Stanford Research SR1 or SR1+ Audio Analyzer
Пока только пару секунд успел оценить, но сразу бросается в "глаза" - немного режущие и рассыпаные вч, легкий подзвон. НО вообще более менее во всем остальном.
Текстовая версия Сейчас: 9.11.2025, 6:13
