Xuelin Ihifi960
freeman86
сообщение 21.11.2013, 21:43
Пользователь №: 516
Решил сделать несколько необычное описание, было интересно, что получится. rolleyes.gif
И в конце инфа в виде текста:
Descriptions:
Ihifi960 is based on ihifi812 from years of research and development .This equipment had joined the rare coaxial / optical fiber output (optical fiber connection can achieve electrical isolation to prevent digital noise transmitted through the ground, so that the signal is more pure), the product can not only carry, more cross-border acts as a pure digital turntable / desktop CD role, providing high-quality end-to-end digital audio, not less than the effect of a high-end CD. Flexible file management is better than desktop CD. While it commendable remains 12 hours of battery life, while 30% smaller.
Filtering use solid state capacitor and polymer capacitor combination,that make power purity reached a new height, making a foundation for the voice of details and reducing the background noise music.
pure sweet sound, dark background, has a simulation feel.
Frameworks:
Audio coupling: top MUSE KZ series ( two )
Filter: Sanyo solid polymer capacitor
LPF: Panasonic capacitor SMD film ( 5%, not ordinary soldering )
Amp: ad8397ardz rail-to-rail amplifier
Decoding: wm8740 (single )
Lpf: lme49720 THD 0.00003%
Src:ad1896
The local clock: 0.5PPM ( Phase noise-125dBc/1KHz ) tcox temperature compensation crystal 11.2896mhz
Power supply: ultra low ripple ( 1mV ) double inductor topologies of DC power supply
Pcb board: 4 layer 2 times on Cu + electromagnetic shielding cover
Interface:
1.Coaxial RCA coaxial digital output interface ( IEC-60958 )
2. optical fiber Optical output interface ( round )
3. LINE OUT line output (share with fiber export )
4. HEADPHONE 3.5mm headphone output interface (a 6.5mm headphones conversion head, can easily drive 16-300ohm. )
5. 12V power charging interface
6. usb data interface
7. tf card interface ( please use class4 Kingston TF Card )
8. analog potentiometer volume adjustment
Technical Parameters:
Headphone output power: 450mw/16ohm220mw/32ohm50mw/300ohm
Coaxial output impedance: 75Ohm
Coaxial output level: 500mv P-P
Line output reference level: 2V ±1.8dB ( 1KHz )
SNR:≥ 109 dB ( A weight )
Channel balance:≤ 1.5dB ( 1KHz )
The degree of channel separation:≥ 95dB ( 1KHz )
frequency response: 20Hz ~20KHz ( +0/-2.5dB )
Total harmonic distortion plus noise: ( 1KHz≤ 0.003% )
Life time: wav format for about 12 hours ( display closed) ape format for about 10 hours ( display off) fiber output state is reduced about 5%
Support audio formats: WAVAPE FLACAAC OGG MP3 WMA ( 8-48k )
Storage capacity: built-in 16GB extension 0-32GB
Battery: 1200mAh 7.4v lithium battery
Net volume: 110*70*26mm
Net weight: 301g
Плеер: IHIFI 960
Наушники: HiSoundAudio PAA-1\ HiSoundAudio PAA-1 PRO\ HiSoundAudio Live\ MYST Nail 2
плеер: Creative X-fi Fatal1ty \ Вега 122с
усилитель: Вега 10у-120с \ Radiotehnika У 7111
наушники: Fostex T50RP \ ТДС-5М
колонки: Radiotehnika 35 АС-201 \ S-30
были: наушники Sennheiser PMX60, Sennheiser HD525, Grado iGrado
плеер: HiSoundAudio RoCoo D
