Hifiman Ef5 Headphone Amplifier, Усилитель/ Ламповик. |
16.6.2010, 16:41
Ламповик. Усилитель HiFiMAN EF5 Headphone amplifier
![]() ![]() ![]() Opamp: OPA275 Tube: RCA Clear top 12AU7 Frequency Response: 20-30K Hz THD+N: less than 0.2% S/N: more than 95dB Input impedance: 50K Ohm Output impedance: 2–2K Ohm headphones Output signal strength: up to 15 Volts at 32 Ohm Input: RCA*1 Output: 1/4 headphone jack*1 Dimension: 110mm(W)*50mm(H)*270mm(D), or 4.33inch(W)*1.97inch (H)*10.63inch (D) Weight:6lb (include packing) Acessory: 12AU7 tube, DY-1 power supply, compatible from 110v to 240v Вот недавно "разжился" и даже успел померить Когда заберу - что-то напишу -------------------- |
| Текстовая версия | Сейчас: 9.11.2025, 6:23 |
